Lockheed Martin’s Composite Transport
  • Lockheed Martin expects to fly a prototype Advanced Composite Cargo Aircraft by October, just one year after winning its $50 million contract.
  • The aircraft utilizes composite materials, reducing weight by up to 30% and significantly decreasing part count from thousands to just 306.
  • This design aims to provide the Air Force with heavier payloads, longer range, significant fuel savings, improved durability against corrosion and fatigue, and enhanced agility for operations on short, rough airstrips.
Lockheed Martin intends to have a prototype Advanced Composite Cargo Aircraft in the air by October, just one year after winning the $50 million contract to produce the plane. The design may be roughly based off of a highly modified Dornier 328J regional jet, but made of synthetic fibers, resin and epoxy instead of metal. Where comparable aircraft could be built from up to 4,000 parts, the new aircraft will be made of just 306 parts and benefit from a weight loss of up to 30 percent versus conventional cargo aircraft. The Air Force is hoping that savings could allow heavier payloads, longer range and significant fuel savings while offering a structure more resistant to corrosion and fatigue. Composite materials are not less expensive than metal, but a faster build time, if achieved, will also contribute to an overall reduction in cost. The prototype aircraft will be smaller than the aging C-130 Hercules, but also more nimble and capable of delivering troops to shorter, rougher strips closer to the front lines.
