NATA Supports Airport Weight-Based Restrictions
  • NATA supports the FAA's proposed weight-based restrictions at airports, primarily to protect pavement from damage caused by overweight aircraft.
  • However, NATA strongly objects to these weight-based restrictions being used as a disguised method to limit aircraft noise or restrict airport access for certain aircraft classes.
  • NATA encourages the FAA to implement restrictions that still provide airport access, avoiding complete bans on specific types of operations.
National Air Transportation Association (NATA) President James K. Coyne urged support of the Federal Aviation Administration’s proposed weight-based restrictions at airports, as long as the restrictions are not used as a substitute for limiting aircraft noise.”It certainly makes sense to protect pavement from damage from aircraft that exceed the design criteria by a significant margin,” said Coyne. “What we would object to is using ‘weight-based restrictions’ as a way to limit noise by restricting access to an airport by a certain class of aircraft.”NATA encourages the FAA to place predominating emphasis on restrictions that still provide access to an airport without a complete ban on operations by a particular type of aircraft.
