New Flight-Plan Rules Take Effect Sunday
  • The FAA is implementing a new IFR flight plan form, effective June 29, but only for flights using RNAV arrival or departure routing.
  • This change is part of harmonizing procedures with ICAO and aims to collect more detailed avionics and aircraft capability information for more efficient ATC routing and a new en route computer system.
  • The new format affects only about 10 percent of general aviation flights, with resources like trained FSS specialists and FAA/AOPA websites available for assistance.
As part of FAA’s ongoing effort to harmonize its paperwork and procedures with the International Civil Aviation Organization (ICAO), the form for filing a flight plan is about to change, but only for IFR flights that include RNAV arrival or departure routing. Pilots filing VFR, or filing IFR but without the RNAV arrivals or departures, can continue to file using the usual flight plan format. Pilots filing point-to-point (RNAV direct) and “T routes” also are not affected. The format change, which takes effect at 0900 UTC June 29, is being made to help expedite the FAA’s transition to a new en route computer system for Air Route Traffic Control Centers. Click here for the text of FAA’s Letter to Airmen. Pilots affected by the change can find more information, including FAQs and step-by-step filing instructions, at the FAA Web site.
The FAA site also includes contact information, with e-mail addresses and phone numbers, to answer any questions. The changes will affect only about 10 percent of general aviation flights, says AOPA. Lockheed Martin flight service station specialists will be trained to help pilots file the new flight plan. “The ICAO flight plan is necessary because it collects more detailed information about actual avionics equipage and aircraft capability,” said Melissa Rudinger, AOPA vice president of regulatory affairs. “This in turn allows ATC to match the most efficient routing to the aircraft capabilities, resulting in better service to pilots.” Pilots with questions about the change can also contact AOPA for more information.
