Delta Weight-and-Balance Outage Delays More Than 1,600 Flights
The airline used manual procedures during the disruption, which affected operations nationwide ahead of Thanksgiving.
[Credit: Matthew Groh / Wikimedia Commons / CC BY-SA 4.0]
  • A malfunction in Delta Air Lines’ automated weight-and-balance system caused more than 1,600 nationwide flight delays during the peak Thanksgiving travel period.
  • The disruption prompted a temporary FAA ground stop and ground delay program at Delta's primary hub in Atlanta, forcing crews to rely on manual workarounds.
  • Operations were restored by Sunday afternoon, with Delta confirming the incident was not a cyberattack and offering rebooking, meals, and accommodations to affected passengers.
A malfunction in Delta Air Lines’ automated weight-and-balance system disrupted flights across the country Sunday, Nov. 22, resulting in more than 1,600 delays during the busy Thanksgiving travel period. According to ABC News, the outage affected a system used to calculate aircraft loading and ensure that departing flights remain within weight and balance limits.
Ground Stop Issued in Atlanta
The airline requested an FAA ground stop for flights bound for Hartsfield-Jackson Atlanta International Airport, Delta’s primary hub. The restriction lasted approximately one hour before transitioning to a ground delay program. Both measures were lifted before noon, according to local reporting. The FAA confirmed that the disruption was unrelated to its air traffic control systems.
“Delta teams are using manual workarounds this morning to safely get flights departed while work continues to restore automation,” the airline said in a statement Sunday.
Operations Restored
Delta confirmed that its automated weight-and-balance systems were operational again by Sunday afternoon. The airline said the outage was not caused by a cyberattack. Approximately 49% of its flights experienced delays exceeding 15 minutes, although some disruptions were attributed to weather. Delta said it was rebooking affected passengers and providing meals, hotel accommodations and refunds where applicable.
The disruption followed a similar system outage at United Airlines on Nov. 16 that temporarily delayed departures nationwide. That incident affected applications used for pilot communications and final aircraft weight calculations. Both incidents occurred shortly after an unrelated FAA telecommunications failure prompted a nationwide ground stop on Nov. 13.
Matt Ryan
