NASA Reschedules X-59 Second Flight for Friday
Test campaign to move into expanded flight envelope phase.
[Credit: NASA/Carla Thomas]
  • NASA has rescheduled the second test flight of its experimental X-59 quiet supersonic aircraft from Thursday to Friday at Edwards, California.
  • The one-hour mission will evaluate early-stage aircraft performance, reaching altitudes up to 20,000 feet and speeds around 260 mph.
  • This flight begins the envelope expansion phase for NASA's Quesst mission, developed with Lockheed Martin to research methods for reducing supersonic noise.
NASA has shifted the timing of the second flight of its X-59 quiet supersonic research aircraft to Friday, adjusting from an earlier plan to fly Thursday. The mission will originate from NASA’s Armstrong Flight Research Center in Edwards, California, and will include operations at nearby Edwards Air Force Base.
The flight is expected to last about one hour and will continue early-stage evaluations of the aircraft’s performance. NASA said it plans to operate the X-59 at about 230 mph at 12,000 feet before climbing to roughly 20,000 feet and accelerating to around 260 mph. The X-59 first flew in October 2025 and primarily focused on initial handling and systems checks.
With this sortie, NASA will begin a sequence of envelope expansion flights, gradually increasing speed and altitude to assess the aircraft under a broader range of conditions. The X-59 is part of NASA’s Quesst mission and was developed with Lockheed Martin’s Skunk Works to study approaches for reducing the noise associated with supersonic flight.
Matt Ryan
