NTSB Urges Better Prop Inspections
  • The NTSB issued a Safety Alert on aluminum propeller failures, attributing them to fatigue cracking caused by undetected surface damage like nicks, pits, or corrosion.
  • Pilots and mechanics are urged to perform thorough preflight and maintenance inspections, promptly repairing any damage to prevent fatigue crack initiation and growth.
  • While backcountry aircraft face increased risk, the NTSB stresses that adherence to recommended overhaul schedules is crucial for all aircraft to prevent blade separations, citing an incident with a Beech 58 Baron.
After investigating a few aluminum propeller failures, the NTSB has issued a Safety Alert and it’s particularly addressing backcountry pilots. “Aluminum propeller blades can be susceptible to fatigue cracking and fracture if a small nick, pit, or corrosion on the surface or edge is not found and repaired during preflight inspection or maintenance,” the NTSB said in the alert. “Such damage can concentrate stress from normal airplane operation loads, resulting in fatigue crack initiation and growth followed by propeller blade fracture.”
The board wants to remind pilots to carefully inspect the prop during each walkaround and get the prop fixed if nicks or cracks are found. It’s also trying to prompt mechanics to make thorough prop inspections part of every annual. Backcountry and aerial spray aircraft are more susceptible because of the increased risk of damage on unimproved runways. But not all blade failures are on Cubs and Cessna taildraggers. The board recently dealt with a Beech 58 Baron that shed a blade on a recent flight. It had last been overhauled eight years previously when it should have been serviced after five years. “If the recommended overhaul had been performed, the corrosion pits that led to fatigue crack initiation would likely have been detected and removed, preventing the blade separation,” the alert said.
