Replacement Cessna Hinges Could Be Defective: McFarlane
  • McFarlane Aviation has issued Service Bulletin SB-10, Revision A, warning of potential material defects and cracking in extruded-aluminum aileron hinges for Cessna aircraft.
  • The affected hinges were produced between February 22, 2019, and January 2, 2020, and can be identified by specific job lot numbers (JO55493, JO55519, JO56823, JO57775, JO60003).
  • A mandatory inspection of these hinges is required within 25 hours time-in-service or 6 months after February 7, 2020, whichever comes first.
  • If extrusion cracks or delamination are found during inspection, immediate replacement of the hinge is required, and McFarlane offers credits for both inspection and replacement.
McFarlane Aviation, which provides a host of replacement parts for Cessna aircraft, has released Service Bulletin SB-10, Revision A, warning that there might be “material defects” in the extruded-aluminum hinges the company sells for Cessna ailerons. These defects could lead to cracking of the hinge. McFarlane says the hinges were produced between Feb. 22, 2019, and Jan. 2, 2020, and isolated to job lots JO55493, JO55519, JO56823, JO57775 and JO60003. (The number is stamped on the part.)
According to the company, “Disassembly and inspection of the McFarlane aileron hinge is mandatory and must be completed within the next 25 hours time-in-service (TIS) after February 7, 2020, or within the next 6 months after February 7, 2020, whichever comes first if the aileron hinge is one of the lots listed in section IV of this service bulletin. If the inspection identifies extrusion cracks or delamination of the hinge bulb, immediate replacement of the hinge is required prior to further flight.”
Locations of possible cracking in extruded hinges.
Inspection requires removal of the hinge pins and partial separation of the control surface from the airplane. A 10X magnifier can be used to detect the cracks. McFarlane is crediting customers with $50 for each aileron inspected and another $40 per aileron hinge for replacement of cracked parts.
mcook
